jglefler
Aug 04, 2020Tutor
Can't Connect AC1200 WiFi Range Extender to the setup page
Hello, I was able to connect my Netgear AC1200 Model EX6120 WiFi Range Extender to the mywifiext setup page with no problems until recently. I recently changed my SSID name but this problem preced...
Aug 05, 2020Guru - Experienced User
When you factory reset push and hold the reset while its powerd on for 7-15 seconds. The lights should flash when held long enough.
When you hardwire into it for setup, disable the wifi on whatever device you're connecting to it so it doesn't default back to the wireless connection.
Try that.
jglefler
Aug 05, 2020Tutor
Excellent information plemans. I really appreciate your prompt reply to my request for help. I will try your suggestions and post the results.
- jgleflerAug 05, 2020Tutor
You are a star, plemans. Your first suggestion worked. I held the reset button in and it started to blink at about 5 seconds. This time I didn't release it at 7 seconds as I did before. I held it for 25 seconds. For the first time NETGEAR_EXT showed up as a network option. I logged on and tried to go to the mywifiext page but it still would not load. I then tried 192.168.1.250 and it worked! I was then able to complete the extender's setup. Thank you so much for your kind help.
- plemansAug 05, 2020Guru - Experienced User
Glad to hear it worked!
