jglefler
Aug 04, 2020Tutor
Can't Connect AC1200 WiFi Range Extender to the setup page
Hello, I was able to connect my Netgear AC1200 Model EX6120 WiFi Range Extender to the mywifiext setup page with no problems until recently. I recently changed my SSID name but this problem preced...
- Aug 05, 2020
Excellent information plemans. I really appreciate your prompt reply to my request for help. I will try your suggestions and post the results.
jglefler
Aug 05, 2020Tutor
jglefler
Aug 05, 2020Tutor
You are a star, plemans. Your first suggestion worked. I held the reset button in and it started to blink at about 5 seconds. This time I didn't release it at 7 seconds as I did before. I held it for 25 seconds. For the first time NETGEAR_EXT showed up as a network option. I logged on and tried to go to the mywifiext page but it still would not load. I then tried 192.168.1.250 and it worked! I was then able to complete the extender's setup. Thank you so much for your kind help.
- plemansAug 05, 2020Guru - Experienced User
Glad to hear it worked!
