jrgo1978
Mar 03, 2023Guide
Can't connect my iPhone to Wifi extender EX8000
Hi everyone I can connect to my AC3000 Wifi Mesh Extender (model EX8000) with my Windows based laptops and have great Wifi/internet signal, no issues at all. However, I have no wifi/no internet serv...
Mar 04, 2023Guru - Experienced User
On the support site for your device, you click downloads and then click on "view previous versions".
From there you can download the older firmware. From there follow the manual firmware update process but use the older firmware.
EX8000 | Nighthawk WiFi Range Extender | NETGEAR Support
jrgo1978
Mar 04, 2023Guide
Thank you so much!
I tried with 4 or 5 different older versions but neither work; at least I can continue using it with my Windows based devices.
Hopefully Netgear releases a new firmware that fixes this issue.
Thanks again!
Thanks again!
- plemansMar 04, 2023Guru - Experienced User
Tried factory resetting it and reinstalling?
Or going into the apple devices and forgetting the network?
- jrgo1978Mar 05, 2023GuideI did it, I actually did it in the website as the app automatically checks for newer firmware versions but somehow it was reinstalled with the latest version, so frustrating!
I also forgot both the 2.4 & 5 Ghz networks but same result.
I truly appreciate taking the time to find solutions, thanks a lot!
