WarrenCl's avatar
WarrenCl
Follower
Dec 10, 2019
Cant connect my WN1000RP
HI,
I have a WN1000RP which previously worked with my old Virgin Media router.
I have tried to connect the new router via method 1 (the router has a wps button) with no joy.
I have tried factory reset and rebooting the router.
The wn1000 flashes, I press the wps button the router nothing happens but after a minute or so the WN1000 all three buttons flash but then just leaves the power light on.
I have tried option 2, I used Firefox (not safari) and go to mywifiext.ne (per manual) and it says not connected to your extenders network, however the NETGEAR_EXT does not appear on either my phone or my imac.
  • Hello WarrenCI,
    May you try factory resetting the unit again and holding down on the reset button for 30+ seconds. Looking forward to hearing back!
    Christian
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello WarrenCI,
    Christian
