msekulich
Feb 28, 2020Initiate
can't connect Nighthawk AC2200 to new Spectrum Wave2 router
I recently exchanged my Spectrum 1-piece modem/router with the new 2-piece 'Wave2' modem and separate router. I can't get the AC2200 extender to connect with this new router via WPS, and my laptop ha...
- Feb 29, 2020
You can still use the smart installation wizard instead of wps.
start off with factory resetting the extender. Push and hold reset while its powered on for 7-15 seconds. Then you can connect to it via the default wireless info on the extender. Use that to run through the smart installation wizard.
here's where the install guide is along with firmware and the manual.
Feb 29, 2020Guru - Experienced User
