ant3000
Aug 08, 2023Guide
Can't connect to AC3000 Desktop Extender (EX8000)
Hi, I have a AC3000 Desktop Extender (EX8000) connected via WiFi to a Nighthawk AC1900 (R7000) VDSL /ADSL Router which I've been running for the last few years with a MacOSX setup I've been attem...
Aug 08, 2023Guru - Experienced User
What result do you get when trying the IP address?
Have you tried hardwiring into the extender and trying?
ant3000
Aug 08, 2023Guide
Hi, The IP Address can't make a connection (I'm on the same network as the Extender) however I have't tried a hardwired connection.
If I hardwire do I connect through the browser using the IP address or the mywifiext address?
- plemansAug 08, 2023Guru - Experienced User
try both
- ant3000Aug 10, 2023Guide
I've hardwired to the extender over Ethernet and still can't form a connection (with without wifi) using the assigned IP, default IP or mywifiext .net or .local (with and without www)
The only time a page has loaded is when I'm not connected to the extender network? All other attempts have timed out or refused to connect?
I have a working connection with the extender over ethernet as I have internet (wifi off) and I also have a NAS attached to the extender but I just can't find a way into the admin?
