alm2020
Apr 03, 2020Tutor
can't connect to extender (EX6100v2)
The range extender shows up as a network to connect to. We selected and put in our wifi password and it won't connect. The wifi password is correct. All the green lights are on, we are close by th...
- Apr 04, 2020
on the support site (https://www.netgear.com/support/product/EX6100v2.aspx) its the second video. the manual also walks you through it.
Apr 03, 2020Guru - Experienced User
Did you setup via wps?
Try redoing the extender setup using the installation wizard. Many times wps wasn't coded the same between manufacturer's and it causes issues. Which is why it also has the installation wizard.
alm2020
Apr 03, 2020Tutor
Thanks.
How do I find the installation wizard?
The extender is now connected to the laptop via ethernet.
- plemansApr 04, 2020Guru - Experienced User
- alm2020Apr 04, 2020Tutor
Thank you, all set now.
