randykepple
Aug 20, 2020Aspirant
Can't Connect to NetGear WiFi Extender Dashboard
My main router is a Netgear CM500 and I'm using a Netgear EX2700 Extender. The issue I'm having is with the extender. In the past, I've been able to log into the dashboard to check firmware, logs, se...
- Aug 21, 2020
If you log into the apple airport and look up the ip address for the extender, can you use that to connect to it?
