randykepple
Aug 20, 2020Aspirant
Can't Connect to NetGear WiFi Extender Dashboard
My main router is a Netgear CM500 and I'm using a Netgear EX2700 Extender. The issue I'm having is with the extender. In the past, I've been able to log into the dashboard to check firmware, logs, se...
- Aug 21, 2020
If you log into the apple airport and look up the ip address for the extender, can you use that to connect to it?
randykepple
Aug 21, 2020Aspirant
Thank you for correcting that mistake! You are correct. The CM-500 is a modem. I do have an Apple Airport Base Station setup as my router. The EX-2700 is the extender and it works fine, but I can no longer log into the dashboard via web browser to update firmware, change settings, etc. It's set up and I'm hesitant to go through the setup process, or reset to factory defaults in fear of losing an entire day fighting with something that should work. All of that aside, I'm open to troubleshooting methods.
Aug 21, 2020Guru - Experienced User
- randykeppleAug 21, 2020Aspirant
Thank you! Brilliant and easy solution! Never would have thought to use the AirPort Utility to log into the base station and grab the IP address for the Netgear extender! By using that IP address, I was able to log in immediately and confirm the firmware needs to be updated, and gain access to the settings.
