Blatzrox
May 25, 2022Aspirant
Can't connect to Roku
May 25, 2022Guru - Experienced User
its the roku that connects to the wifi. Not the other way around.
What router do you have?
what modem do you have?
what error are you getting?
did you check with roku?
Blatzrox
May 27, 2022Aspirant
Actually, I can connect to my Roku, and my Netgear extender shows up, but when I go to put it on, it says that I'm not connected to the internet. It worked fine for awhile, but now all of a sudden when I try to use the Netgear extender signal, the Roku player says it's not connected to the internet. I have tried to restart the home router, and tried to put the extender in the same room as the router as I did when I 1st got it to set it up. I just don't understand why all of a sudden I can't connect to the internet now. Roku player is doing fine. Can anyone help me?
