Habs1292
Aug 07, 2023Follower
Can't connect to WiFi extender on my phone
I've got eh netgwar WiFi extender 300?, (it's been many years since I bought it). Recently we had some moving around to do and I temporarily unplugged it. I plugged it back in and tried connecting to ...
schumaku
Aug 08, 2023Guru - Experienced User
Good thing is there are usually product labels attached, which does show the model designation. If unclear, take a picture and post. Head to https://www.netgear.com/support/ and start entering the product type, like WN2000RP, WN3000RPv3, EX2700, ...
Habs1292 wrote:
I plugged it back in and tried connecting to it on my phone and it asked for 'authentication'. This is very normal and as with all Android phones a little notification popped up at the top to click to authenticate. Whenever I click this notification however I get sent to a blank screen which says something to the tune of 'error, reset.'1''. This doesn't happen on any other device except my phone?
When configuring an SSID for the first time, it does ask for the password (PSK), offers options for using randnomised MAC (default) or Use device MAC.
Either way, if you don't know the current status of the extender exactly, get the Quick Strat and follow the installation processes from the device User Manual.
