Forsh75
Jul 23, 2014Novice
Can't connect to WN3000RP
Hi, I have my extender connected to my router and I have 4 green lights on the extender. When I try to connect to it using ipad, phone or mac I just get the spinning wheel. This stays on for ages, ...
storm_2003
Jul 23, 2014Novice
What is the router model this extender will be connected to?
What is the firmware version running on your WN3000RP?
What is the IP address of your Router?
What is the IP address received on your wireless clients?
If you have a wired computer kindly connect it with an Ethernet cable to the WN3000RP and check if you get a valid IP address from your router.
