Forsh75
Jul 23, 2014Novice
Can't connect to WN3000RP
Hi, I have my extender connected to my router and I have 4 green lights on the extender. When I try to connect to it using ipad, phone or mac I just get the spinning wheel. This stays on for ages, ...
Forsh75
Jul 25, 2014Novice
- When I do this I get all 4 lights lit but nothing can connect to it, wheel just spins and spins.
storm_2003 wrote: What is the router model this extender will be connected to? - Dreytek Vigor 2710
What is the firmware version running on your WN3000RP? The latest version.
What is the IP address of your Router? 192.168.1.1.
What is the IP address received on your wireless clients? anything from 192.168.1.30 to .80
If you have a wired computer kindly connect it with an Ethernet cable to the WN3000RP and check if you get a valid IP address from your router.
I've tried to get into the admin of the extender but whenever I go to 192.168.1.250 I just get sent to the wifi connection page and asked to enter my WPA key.
Thanks
