Forsh75
Jul 23, 2014Novice
Can't connect to WN3000RP
Hi, I have my extender connected to my router and I have 4 green lights on the extender. When I try to connect to it using ipad, phone or mac I just get the spinning wheel. This stays on for ages, ...
storm_2003
Jul 25, 2014Novice
From the location where your WN3000RP, does your ipad, phone can connect to your Dreytek Vigor 2710 wireless SSID and able to go online?
Please try accessing the GUI through mywifiext.net or ping it. It should reply with the WN3000RP's IP address(if the IP changed).
btw did you set the SSID for the WN3000RP same as your router?
