CNG_
Nov 22, 2021Initiate
Can't convert AC1900 WiFi Mesh Extender (EX7000) into an access point
Hello, I am attempting to turn my Nighthawk router into an AP. I can extend the wireless network successfully, but the issue I am experiencing is that when I plug the extender into the router, ...
- Nov 22, 2021
You need to re-run setup and set it up for access point mode.
So disconnect it from your router, factory reset it.
Then go through the setup process using the installation assistant.
During that it'll give you the option of setting up as an extender or as an access point.
Set it up as an access point.
Then connect it to your router.
CNG_
This suggestion worked. Thank you!
After a factory reset, I set up the extender as an access point, and I am getting more consistent internet speeds in the designated wifi coverage area.
I am using a powerline adapter in between the router and Nighthawk. I noticed the internet speeds are 28% slower than if the Nighthawk was directly connected to the router.
Is there any way to change the speeds, or is the decrease on par for the course with powerline adapters?
Thanks again!
CNG_
Nov 23, 2021Guru - Experienced User
You can test the power line. Simply plug your pc/laptop into the powerline where its located and test it.
You do lose a bit of speed with powerline depending on a lot of factors so its tough to tell how much you should expect.
