chortlesteve
Nov 08, 2012Follower
Can't do a factory reset: WN2000RPT
Hi I'm having trouble connecting to my WN2000RPT, which I haven't used for a while, just getting a 'timeout' each time. So I wanted to do a factory reset to start anew. But pressing the button w...
jmizoguchi
Mar 16, 2014Virtuoso
If the unit still under the warranty then you may want to contact support for possible RMA.
http://my.netgear.com
