chortlesteve
Nov 08, 2012Follower
Can't do a factory reset: WN2000RPT
Hi I'm having trouble connecting to my WN2000RPT, which I haven't used for a while, just getting a 'timeout' each time. So I wanted to do a factory reset to start anew. But pressing the button w...
Zedd
Mar 16, 2014Aspirant
jmizoguchi wrote: If the unit still under the warranty then you may want to contact support for possible RMA.
Thanks. After the tricky reset (keeping the reset button pushed while turning it on) - I turned the device off and then when I turned it on again it worked. I could connect to 192.168.1.250 and configured it.
How much is the standard warranty for NetGear devices, by the way? I can't remember how much they said at the shop when I bought it.
Thanks.
