Torposaurus
Oct 05, 2025Aspirant
Can't find NETGEAR_EXT
I have a NETGEAR AX1800 Mesh extender, Model: EAX15 I have previously used it in a different apartment without issue, but now when trying to install it in a new home, it wont provide the NETGEAR_...
CrimpOn
Oct 05, 2025Guru - Experienced User
Torposaurus wrote:tried to factory reset numerous times,
I find it a bit awkward to hold the paperclip in that tiny hole when this product is plugged into a wall outlet. My solution has been to plug the extender into an extension cord for the reset process. (I actually do all the setup with WiFi extenders using an extension cord and then plug the extender into a wall outlet when the setup is finished.)
Torposaurus wrote:no light starts blinking
Wireless Protected Setup (WPS) has two uses on this product:
- To connect the EAX15 to the host network (page 12), and
- To connect devices to the EAX WiFi (page 19).
https://www.downloads.netgear.com/files/GDC/EAX15/EAX15_UM_EN.pdf
- TorposaurusOct 06, 2025Aspirant
I meant to say I’ve successfully factory reset the device multiple times, but it hasn’t helped. At least I think I have. I’ve pushed the button until the orange light starts blinking, then released, and after a while the solid orange turns green.
As for the WPS, yes what you are saying is what I’m trying to use it for, but the device doesn’t react to me pushing the button like the instructions suggest. No WPS light starts blinking flashing green like the instructions say it should.
