hanneske26
Apr 27, 2022Tutor
Cant find router in Nighthawk app
With the latest app update i cant connect my mighthawk app with the Extender EX8000 The extender is working but the nighthawk app cannot find the router i can login with browser in extender and a...
Apr 28, 2022Guru - Experienced User
Are you using a iphone?
If so, make sure to disable icloud relay, random mac, random ip.
I've seen them cause a slot of issues lately
- hanneske26Apr 28, 2022Tutor
I'm using i iphone
tried the solution disable iCloud, ip en mac but that doest do the trick
johan
- plemansApr 28, 2022Guru - Experienced User
Tried uninstalling the app and reinstalling?
It works fine through the browser though?
- hanneske26Apr 28, 2022TutorYes tried that to but app wont find extender
And yes works fine trough browser but the app cant Connect
