hanneske26
Apr 27, 2022Tutor
Cant find router in Nighthawk app
With the latest app update i cant connect my mighthawk app with the Extender EX8000 The extender is working but the nighthawk app cannot find the router i can login with browser in extender and a...
hanneske26
Apr 28, 2022Tutor
I'm using i iphone
tried the solution disable iCloud, ip en mac but that doest do the trick
johan
Apr 28, 2022Guru - Experienced User
Tried uninstalling the app and reinstalling?
It works fine through the browser though?
- hanneske26Apr 28, 2022TutorYes tried that to but app wont find extender
And yes works fine trough browser but the app cant Connect- santosmarcoApr 30, 2022Aspirant
I have the same problem over the last 3 weeks, same exactly issue.
Nothing fix the issue, I am waiting a next app update to see if they fix that.
Everything is working perfect on the browser and also I checked with my network monitoring tools (FING and WireShark)
PS: I have this same apps installed on Android device, and it work without any problem, the issue is related to the iOS version.
