mjb3824
Apr 02, 2019Aspirant
can't load firmware for wifi extender
I’ve tried to update the firmware on my wifi extender, however, when I type in the model number, it isn’t recognised. The models identified are ‘6200-AC1200’ and ‘6200-AC v2’. The model of my exten...
- Apr 04, 2019
Good to hear. Glad it worked. Please mark you post as solved so others will know for future reference. Enjoy. :smileywink:
Apr 03, 2019Guru - Experienced User
What Firmware version is loaded on the EX?
Waht region are you located?
Does this FW version work?
https://www.netgear.com/support/product/EX6200.aspx#download
