prdbman
Feb 20, 2023Guide
cant reconnect ex6150
My ex6150 was working well for a few years but all of a sudden I starting have some issues so I decided to do a factory reset and start over. I havent been able to get it setup since. I am able t...
Feb 21, 2023Guru - Experienced User
What fios router is it? Some of verizon's newer ones have son (self organizing network) built in and that needs to be disabled to use non verizon extenders.
- prdbmanFeb 21, 2023Guide
The fios router is G-1100 Quantum Gateway. I don't see anything about self-organizing gateway but will look further. Thanks!
- plemansFeb 21, 2023Guru - Experienced User
the G1100 has a wps option through the settings. Have you tried setting them up using wps?
Yes I just tried that. Everything seems to work. All lights are green. But I dont see the new network (ie MyWiFiExample_EXT) after the setup.
I appreciate your suggestion though ... thanks!
