bigdogmurphy's avatar
bigdogmurphy
Follower
Apr 19, 2022
Can't remember password to AC1200 extender.
Power went off.  Can't remember password to log-in to the extender.  Is there a way to reset it?
1 Reply
  • plemans's avatar
    Yes, you can factory reset it.
    Push and hold reset for 7-15 seconds while powered on.
    then follow the install guide.
    There's a support site with access to manuals, firmware, install guides, etc.
    Go to https://www.netgear.com/support/
    Type in your model number and from there it'll take you to the above.
    Its a great resource to start with.
