studlyriverrat's avatar
Mar 26, 2021
Can't Reset/Connect
Running Windows 10 throughout via ATT Internet router. After initial Extender installation, never able to connect to 2.4GHz network that had the stronger signal. Always defaulted to 5 GHz. When the 2...
  • plemans's avatar
    Mar 26, 2021
    What actual router do you have?
    Did you set it up using wps or using the installation assistant?
    I'd highly recommend installing the extender using the installation assistant
