BBK91
Aug 25, 2022Tutor
can't see WiFi network NETGEAR_EXT when setting up AX1800 WiFi 6 4 Stream Mesh Extender
Hello! I am trying to install my AX1800 WiFi 6 4 Stream Mesh Extender and I am unable to see the WiFi network NETGEAR_EXT on either my Android nor my computer. The Extender is plugged into the rout...
- Aug 25, 2022
Glad it worked!
You might mark it solved so other aren't still trying to fix it 🙂
Aug 25, 2022Guru - Experienced User
Did you click the wps button at all? if so, it sets it up with a mesh network (meaning it uses the same ssid as the router).
also, are you planning on leaving it hardwired into the router? If so, you'll want to set it up in access point mode.
What I'd do? Start over. Push and hold reset for 7-15 seconds while powered on. That should get you back to stock. have it unplgged from the router. Go through your setup. IF you're planning on leaving it hardwired in, then set it up in access point mode. IF you plan on using it as an extender (not hardwired in), then use extender mode.
BBK91
Aug 25, 2022Tutor
Thank you! I just reset the extender and no, I was not planning on leaving it hardwired. You mention about the WPS button. I did not click that. Should I?
