BBK91
Aug 25, 2022Tutor
can't see WiFi network NETGEAR_EXT when setting up AX1800 WiFi 6 4 Stream Mesh Extender
Hello! I am trying to install my AX1800 WiFi 6 4 Stream Mesh Extender and I am unable to see the WiFi network NETGEAR_EXT on either my Android nor my computer. The Extender is plugged into the rout...
- Aug 25, 2022
Glad it worked!
You might mark it solved so other aren't still trying to fix it 🙂
BBK91
Aug 25, 2022Tutor
Thank you! I just reset the extender and no, I was not planning on leaving it hardwired. You mention about the WPS button. I did not click that. Should I?
