April_S
Jan 25, 2012Novice
Can't set parental controls. Please Help
I don't know if this is the right place to find help, but... Does anyone know how to download the Netgear Management Utility file so that I can set parental controls? My computer says there is an ...
aclow
Mar 19, 2012Aspirant
It sounds like you're trying to use an Apple Mac or similar to use the Management Utility, but it only runs on Windows. If you have a Windows machine, use it, otherwise I don't think you can get started. I have a windows PC but the Management Utility freezes when I start it - I can't find a way round this problem at the router itself, so I can't help you out, sorry.
