mhenry9632's avatar
mhenry9632
Cant set up wifi extender Ex2700
Hi all. This may be a daft question but I am trying to set up my extender using the installation assistant on my mobile phone as there is no wps option on my router. To do so I need to connect to the netgear extender by wifi for it to link and then recognise to start the set up. However in doing so I then have no internet connection so I cant go through the steps. How do I set this up linked to a netgear device that itself has no wifi until I can connect it to my router. Seems odd. May be so.ethong simple but any help appreciated. Thanks
    • mhenry9632's avatar
      mhenry9632
      Thanks as not seen the video but it doesnt solve the problem When I connect to the booster I have no internet so I cant complete the steps to set it up. I assume the point of going through the steps is so the booster can pick up the router wifi signal and therefore doesnt have one itself. By connecting to the booster before connection it has no wifi which seems to defeat the object. No idea what to try other than return it.
      • plemans's avatar
        I guess I'm a bit confused.
        Not a single extender has internet until you connect to it and go through the full setup process.  it doesn't matter which extender or manufacturer you go with.
        Why do you think it should have internet if it isn't setup yet?
        Where in the process is is failing? maybe a better description of whats going on exactly will help. either describe where its failing or even better take a video of the process.
        What router are you connecting to?
        Are you trying to setup in the same room? After you get it setup, you can move the extender.
