pissotds
Mar 31, 2022Follower
cant turnoff Fastlane
I can not return to the basic mode. Select Basic then "SAVE" next page the"NEXT" option wont execute.
Mar 31, 2022Guru - Experienced User
What device do you have?
The RAX80 from your signature is a router and not an extender so it won't have fastlane.
IF you truly have an extender, you could always just factory reset it and then reinstall it
