EdNetPR
Dec 28, 2020Initiate
Can't Update EX2700 Firmware Firmware Version: V1.0.1.52 TO 1.01.58
I have tried several times to update the router firmware using the Netgear app (Check for update; but the update keeps failing. Downloaded the file, then when I tried to upload the update file I get ...
- Dec 29, 2020
after you downloaded it, did you extract it?
https://kb.netgear.com/000061572/How-do-I-manually-update-the-firmware-on-my-NETGEAR-WiFi-Extender
Dec 29, 2020Guru - Experienced User
EdNetPR
Dec 30, 2020Initiate
plemans wrote:after you downloaded it, did you extract it?
No. That was the problem; completely missed step #7. Thanks a lot for your help.
- plemansDec 31, 2020Guru - Experienced User
Glad you got it working!
