will8iam
Feb 23, 2026Aspirant
CAX30S and EAX80 Not Connecting
This is the first time I have set up own internet modem/router combo and an extender, and I have been running into a series of issue through out the first couple of months of setting it all up. Here ...
Feb 24, 2026Guru - Experienced User
The problem with using multiple extenders is that they can end up connecting to each other and not back to the primary router. It creates instability and issues especially if the extenders are to close together.
- how big is the home?
- how far apart (distance) are the extenders from each other and the router?
- what is in between each (walls/appliances/etc) and what are the walls/floor made of?
Usually I tell people who are trying to use extenders that its only fine if they can be spaced far enough apart and usually I tell them to even avoid that. Using 1 extender is fine. More than 1 and its better to switch to an actual mesh system where there's something controlling the system (the router). In a mesh system built with extenders, nothings controlling them. So its ends up janky. If you're set on using both extenders, try naming the router's ssid something different and then manually connect the extenders to the router and given the extender's their own name. That way they're forced to connect back to the router and not end up connecting to each other. Ruins the point of a "mesh" but its what you have to do when you're cobbling a mesh system together
- will8iamFeb 24, 2026Aspirant
- The sqft is about 2300, with a little over 900 sqft on the 2nd and 3rd floor and under 450 on the 1st.
- The Extenders are on the 1st and 3rd floor on opposite sides of the house. Cannot get an actual value but I would say they are placed the furthest possible from eachother. The Router is on the 2nd floor but because of the location of the coax outlet, it is closer to the back end of the house. So its closer to the extender on the 1st floor.
- Wood, HVAC system, Plumbing, typical Wood and Dry Wall material found in the North East homes of the USA.
I did rename them to be different from the Router. My current working theory is that the distance from the router to the Extender on the 3rd floor is too far, causing a latency on performance. It does connect, but the internet is not reliable for anything requiring constant connection(gaming, live streaming, communication). The working plan is to move the extender temporarily more central to the 2nd floor to see if the connection improves while connected to Ethernet, then to either permanently move the Router or Extender to a move central position on their respective floors.
As for why I chose this system the way it is, it is because I need to be able to provide Ethernet level internet speeds to both the 1st and 3rd floor for work purpose without being able to run a cable through the house. Additionally, none of the mesh systems were listed as acceptable 3rd party devices in my area.
