Jansimms51
May 29, 2022Follower
Centurylink C4000BZ
I have this dsl router from Centurylink. I would like to connect the Netgear wifi range extender to it. How do i do this and make it work.
May 30, 2022Guru - Experienced User
You should be able to simply install the extender using the installation assistant.
have you tried that?
what extender do you have?
What method of setup are you using?
Where is it failing in the process?
