Valentin161
Dec 09, 2019Aspirant
Change wifi channel A7000 USB adapter
Hi everyone, I recently bought an A7000 USB adapter. That's a great product. However, I spotted that on the wifi channel number "1" of my router, the connection is really bad. Whereas on other chan...
- Dec 09, 2019
channel 1 is 2.4ghz while the higher channels are 5ghz. 5ghz has much higher throughput than 2.4ghz channels. It just doesn't penetrate objects as well or transmit as far.
to "forbid it" connecting to channels 1, just seperate out your 2.4ghz and 5ghz ssid's on your router. Then forget the 2.4ghz network and soley connect to the 5ghz.
Also, your posting in the range extender forum and not the wifi adapter forum.
https://community.netgear.com/t5/WiFi-Adapters/bd-p/home-wifi-adapters
Dec 09, 2019Guru - Experienced User
- Valentin161Dec 09, 2019Aspirant
Thanks for your reply !
