AMP123
Jul 07, 2024Aspirant
Changing Default Network EX3700
I'm trying to connect my EX3700 range extender to an existing network with a range 192.168.68.x I can see and connect to my existing SSIDs on the EX3700, but it insists on using it's preferred ra...
- Jul 08, 2024
I dug the EX3700 out of my "Box of Stuff". Oh, my. Things have changed since 2018 when this device came on the market. WiFi extenders are so inexpensive now that I would be likely to purchase a modern one. Anyway....
Can you verify how this page appears on your EX3700:
CrimpOn
Jul 07, 2024Guru - Experienced User
Is this EX3700 in Extender Mode or Access Point mode?
- AMP123Jul 08, 2024Aspirant
I'm trying to run it in extender mode
- CrimpOnJul 08, 2024Guru - Experienced User
Thank you Crimpon ... that's the solution - it was hiding off the bottom of the page!
I got this device in a bargain bucket so it was worth a shot for a fairly simple task, otherwise I would have gone something more modern as you suggest.
