m00rE
Nov 14, 2019Aspirant
Changing EX 7000 SSIS paswords
I forgot one the two passowrds for my dual band EX 7000 range extender. How can I easily reset the PW for the bandI have forgotten the PW?
Nov 14, 2019Guru - Experienced User
login to the extender through the working ssid (the one you know). Once logged into the extender, you can change ssid's and passwords.
mywifiext.net
Or you can log in via a hardwired device. this bypasses needing the ssid password. You just need to know your gui login info
- m00rENov 14, 2019Aspirant
and how do I find my GUI login details?
- plemansNov 14, 2019Guru - Experienced User
hopefully you remember them.
The defaults are:
login: admin
password: password
if you changed them and don't remember them, the only way back in is to factory reset it and start back from fresh. To do that, push the reset button (while powered on) for 7-10 seconds, until the lights change.
Not sure how to get to the GUI.
