geneeckhart
Dec 07, 2020Tutor
Changing the wifi password on my extender
The problem is that I had to replace my Comcast cable modem and had to reset my password for the wireless network contained in the Comcast modem that my mesh extender connects to. Now it won't conne...
Dec 07, 2020Guru - Experienced User
You can just factory reset and reinstall the extender. Might be the fastest route.
Push and hold reset for 7-15 seconds while its powered on. then just follow the install guide.
- geneeckhartDec 07, 2020Tutor
That did it. Thanks so much.
- plemansDec 08, 2020Guru - Experienced User
glad to hear it got it working. you can mark it solved so others aren't trying to fix it as well.
Thanks!
