Azurelink
Sep 21, 2021Star
Changing to a new Network Procedure - Airbridge WBC502B2
I am having problems switching my Insight Instant Airbridge from one Comcast network Internet connection to another Internet-only router. The cable modem and router are Motorola units and the Lan por...
Sep 22, 2021Guru - Experienced User
You might get more help on the business wireless forum.
I didn't see a forum specifically for the airbridge (netgear doesn't make it easy to choose forums) but the business side of it is going to have more people that use that product as well as the moderators on there tend to be a bit more involved.
https://community.netgear.com/t5/Business-Wireless/bd-p/business-wireless-for-business
Did you try factory resetting the airbridge setup and starting over?
Azurelink
Sep 22, 2021Star
Thanks Plemons! I'll do that. You'd think it would be as simple as just pluging into the new router...
- plemansSep 22, 2021Guru - Experienced User
It should be that simple. but something might have changed enough a new setup is needed. And I've never used that device to know much about it other than the basics. The business wireless might have :)
