AlbertPeabody
Oct 23, 2024Follower
Changing to new Wifi on EZ7000
My wifi system has changed and the old wifi is not available. How do i change settings to the new wifi system?
- Oct 23, 2024
there isn't a EZ7000.
What actual device do you have?
Is it an extender?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
Oct 23, 2024Guru - Experienced User
Is it an extender?
