pquebodeaux
Mar 21, 2022Guide
Channel connectivity issues
I have been having some connection issues with my extender ever since I replaced and upgraded my modem from AT&T to fiber optic. Now, it connects to WiFi, but the channels won't connect, that being ...
Mar 21, 2022Guru - Experienced User
1. What actual router/gateway do you have from att?
2. you have the ex7500? what firmware is on it?
3. if you have the ex7500, factory reset it. Then during the install process (using the installation assistant), uncheck the "extend 2.4ghz" box. You'll still be able to use 2.4ghz but the ex7500 will only use the dedicated 5ghz as backhaul. I've seen it use the 2.4ghz as failover and cause instability issues.
- pquebodeauxMar 21, 2022Guide
Thanks for your response. The router that AT&T installed is a BGW320. The firmware is V1.0.1.76_1.0.80. I have performed the factory reset numerous times but I will uncheck the 2.4GHz box this time and try that. Thanks again.
- pquebodeauxMar 22, 2022GuideTried the reset but still not working.
- plemansMar 22, 2022Guru - Experienced User
Whats it showing on the connections page status? (it'll show backhaul/fronthaul connection info)
Are you getting an error?
Are you using the one wifi feature? Or smart connect?
