schilea
Nov 15, 2020Aspirant
Channels selection for Extender EX7700 working as Access Point
Hi, I am having the next configuration: - front entrance R7800 X4S. Not possible to move it centrally as I am having Cat5E cables between the entrance (via a niche in the wall) and each room. - Ca...
Nov 15, 2020Guru - Experienced User
When the EX7700 is running in ap mode, it doesn't function as a mesh device. Its why you're getting drops. it only functions as a mesh device when running in extender mode.
You can use the same ssid as the primary router but devices will tend to be sticky and not roam properly. they stay connected to 1 device until their signal becauses unusable/drop entirely.
So if you want it to function as a mesh setup, connect it using extender mode without the hardwired backhaul.
If you'd rather have it in ap mode, i'd recommend using different ssids between the 2 devices. Also make sure they're (router/extender) on different wireless channels so they don't interfere with each other.
- schileaNov 15, 2020Aspirant
Thanks, this what I was initially thinking of, but I have seen some posts not confirming this approach.
Also, this is beyond my understanding, Netgear is implementing mesh using a less reliable 5G band and is not using for this the more reliable ethernet connectivity.
- plemansNov 15, 2020Guru - Experienced User
The only system that supports wired backhaul (currently anyway) with mesh is the orbi mesh systems.
the extenders have to use a different setup since they're designed to operate with all routers, not just orbi routers.
If you want a wired backhaul, then you'd need a full mesh system and not just a mesh extender.
- schileaNov 15, 2020AspirantHi, what you said is not according to Netgear documentation https://kb.netgear.com/000060286/How-do-I-install-my-Nighthawk-Mesh-WiFi-Range-Extender-as-an-Access-Point
7 Click Access Point.
The setup verifies your Internet connection.
8. Enter the network name (SSID) and password of your router’s network.
Note: Using the same WiFi credentials as your router enables your extender to support the One WiFi Name feature. With One WiFi Name enabled, everyone in your network is able to move between your router and extender’s signal with no network interruptions.
Thanks,
Silviu
