traveler558
Apr 29, 2020Follower
Choosing a Range Extender compatible with RAX 50
I recently installed a Nighthawk RAX50. This is the third Netgear router I've had. I have had fairly good success with them over the years. I like the Android app that allows me to do some managem...
Apr 30, 2020Guru - Experienced User
What range extender were you using? They should still be compatible with the RAX.
Pretty much all of netgear's range extenders would work. I'm a fan of the tri-bands because they don't take the loss of bandwidth and increased latency that most extenders take.
