jeth
Apr 19, 2013Aspirant
command to reset wireless
Is there are any to issue the command to reset the wireless section of the router without going through all of the router menus? Wireless frequently stops working and I have to either to a power ...
jeth
Apr 20, 2013Aspirant
I don't know what happened just then, but in the middle of trying to reply, I must have hit the wrong key.......
Otheers may be using wireless and obviously would want unit to be reset.
However if one is using a wired connection, and in the middle of something, she tends to get upset if I have to use the simpler power off/om approach.
