Luka1's avatar
Luka1
compatibilità tra R8000P e extender
Ciao a tutti, possiedo un router R8000P e ho bisogno di affiancargli un extender. Vorrei un aiuto per capire quale, per caratteristiche, è il più adatto tra EX8000, EAX20 e EAX80 per l'R8000P. Preme...
  • plemans's avatar
    Feb 02, 2021
    If you're near an area with radar, whenever it picks up radar, it has to switch of dfs channels. It can cause drops/irregularity in service if your in one of those areas .
    Another thing you can try is the R8000P is the backbone of the system. Maybe its having issues on that firmware. the firmware I'd recommend is 1.4.1.42 for that router. Install it over a hardwired connection. then do a factory reset and clean install (not using a backup). disable auto-updates and try it for a period.
