JohnBrichacek
May 09, 2021Follower
Compatibility with Windstream modem
Is the NIGHTGEAR Nighthawk AC200 WiFi Mesh Extender EX 7700 compatible with all modems? I have a Windstream Gateway Modem with 50 Mbps?
May 09, 2021Guru - Experienced User
The EX7700 needs to connect to a router. Not a modem.
If your windstream device is a modem/router combo device, then it should work with it.
What windstream gateway is it?
