jtchaney
Mar 27, 2022Tutor
Compatible Range Extender for R9000
I’m not completely a tech savvy person. Know just enough to get something connected properly… and it work, as intended. With that said, a lot of the jargon for extenders on the Netgear site store is l...
- Mar 28, 2022
jtchaney wrote:
Thank you so much for your assistance. It’s single level off-ground construction, on approximately a 3 ft. crawl space. Materials are all wood with drywall interior, stucco exterior.---leaves potential for running ethernet wires under the home if needed. Nice. Having a hardwired option is always a benefit.
Moving router is doable. But you suggest, also getting an extender? Based on this info (our uses) which would be your suggestion as a compatible model with our router?---2000sqft all on one level is a bit more area to cover that 2000sqft on a dual/tri level home. You'd probably be better off with a router/extender combo. If you're not hardwiring in the extender, I'd be looking at the triband extenders (ex7500, EX7700, EX8000) to go with that router. They perform much better than the dual band extenders.
Currently we have set everything set up on the lower 2.4ghz, which I thought was correct. We should move the media devices, like TV, phones/tablets to 5ghz, and leave all else on 2.4?---Correct. Your streaming devices (if the signal reaches) should be on 5ghz. Its a significantly faster network and doesn't have as much interference. For example, in my area, I max out around 30-50mbps over AC and 70-80mbps over AX wireless on the 2.4ghz. For 5ghz i can hit 500-600mbps on AC networks and over a gigabit on AX networks. Its much better for streaming/higher bandwidth devices.
Mar 27, 2022Guru - Experienced User
I'm a fan of the triband extenders because of their dedicated backhaul.
The single/dual band extenders have a 50% throughput loss because of how they function. they have to use the same chip to go router---extender and then extender----devices. and they can't do both at once. that's why they loose so much throughput. Versus the tribands with their dedicated backhauls, don't loose that speed.
tribands: EX7500, EX7700, EX8000, RBS40V/RBS50Y (both have an extender mode)
