Susie_k4
Jun 13, 2019Initiate
Computer not detecting netgear wn1000rp
I am trying to set up my range extender on my home computer and it is not being detected. Worked fine on my iPad and iPhone. I have pressed the top button on the unit and the green light blinks but s...
Jun 13, 2019Guru - Experienced User
I'm just wanting to clarify.
The device is connected back to router fine? You have that working since you say ipad and iphone work with it. Is this correct?
You're struggling to get your main computer working on it?
From the sounds of it you're hitting the wps button on the device to try to sync the computer to it.
Have you logged into the extender and setup its ssid and password? If so you don't need to use wps, you can just connect to the broadcast ssid and password.
What firmware is on the extender?
here's your manual. It has information on setting up the ssid and logging into the extender.
- Susie_k4Jun 13, 2019Initiate
I am connected to the _ext (netgear WiFi booster) on my IPad. I tried going to mywifiext.net and it says I am not connected to my extenders WiFi network.
Also, not able to find the WiFi _ext on my home computer at all. I did follow the manual’s instructions just not able to get far with it.
- plemansJun 14, 2019Guru - Experienced User
What router are you using?
Firmware on router and on extender?
If you go into your router, most have a connected devices page (or similar for non-netgear routers) that will display connected devices. Does your extender show up here? It if does, it should have an ip adderss, use this to try to log into the extender.
