Susie_k4
Jun 13, 2019Initiate
Computer not detecting netgear wn1000rp
I am trying to set up my range extender on my home computer and it is not being detected. Worked fine on my iPad and iPhone. I have pressed the top button on the unit and the green light blinks but s...
Susie_k4
I am connected to the _ext (netgear WiFi booster) on my IPad. I tried going to mywifiext.net and it says I am not connected to my extenders WiFi network.
Also, not able to find the WiFi _ext on my home computer at all. I did follow the manual’s instructions just not able to get far with it.
Jun 14, 2019Guru - Experienced User
What router are you using?
Firmware on router and on extender?
If you go into your router, most have a connected devices page (or similar for non-netgear routers) that will display connected devices. Does your extender show up here? It if does, it should have an ip adderss, use this to try to log into the extender.
