camahide
Feb 03, 2020Follower
Computer suddenly unable to connect to EX2700
Using NETGEAR WiFi Range Extender EX2700 and a Belkin N300 Wireless USB Adapter I reinstalled windows to an SSD, and was able to connect to the extender through the windows installation wizard. ...
Feb 04, 2020Guru - Experienced User
Usually when all devices except for 1 are working fine, it tends to be the device that isn't working. Not the extender. This seems to point even more in that direct if it was working prior.
What belkin adapter are you using?
Some require the drivers to be installed in a particular order and without the adapter plugged in.
Have you tried uninstalling the drivers and letting windows self install the drivers?
Or look it up on the belkin website the proper order and drivers for that specific device?
