idh7
Mar 22, 2026Aspirant
Computers stopped connecting to my Nighthawk X65AC3000
Since purchasing I have had no issues connecting to my extender but in the last few days my computers have stopped connecting. I have rebooted the Nighthawk and the lights show connection to my incom...
Mar 23, 2026Guru - Experienced User
What router is it connected to?
Did you install it with WPS or using the installation assistant? I'd reset it and install it using the assistant
- idh7Apr 01, 2026Aspirant
Virgin media, my provider in UK supply a Sagemcom Hub5 router which when placed in my downstairs lounge left a two room blank area upstairs. The Nighthawk filled that gap for a few years. If ever it dropped all I had to do is reboot the Nighthawk and it was running again. Now my upstairs PC and other items upstairs will not connect to Nighthawk despite is showing a full signal.
I have restored the Nighthawk twice to factory settings. First time I used WPS (the original method I used) and then manually and in both cases connection went perfectly except nothing will connect to Nighthawk even though it shows a 5 bar signal and is definitely connected to the incoming router.
I have moved the main router to my main hall in a rather unsightly position but I am able to pick up a weak signal upstairs as a temporary measure but would live to have my Nighthawk working again.
