idh7
Mar 22, 2026Aspirant
Computers stopped connecting to my Nighthawk X65AC3000
Since purchasing I have had no issues connecting to my extender but in the last few days my computers have stopped connecting. I have rebooted the Nighthawk and the lights show connection to my incom...
Mar 23, 2026Guru - Experienced User
What router is it connected to?
Did you install it with WPS or using the installation assistant? I'd reset it and install it using the assistant
idh7
Apr 01, 2026Aspirant
Virgin media, my provider in UK supply a Sagemcom Hub5 router which when placed in my downstairs lounge left a two room blank area upstairs. The Nighthawk filled that gap for a few years. If ever it dropped all I had to do is reboot the Nighthawk and it was running again. Now my upstairs PC and other items upstairs will not connect to Nighthawk despite is showing a full signal.
I have restored the Nighthawk twice to factory settings. First time I used WPS (the original method I used) and then manually and in both cases connection went perfectly except nothing will connect to Nighthawk even though it shows a 5 bar signal and is definitely connected to the incoming router.
I have moved the main router to my main hall in a rather unsightly position but I am able to pick up a weak signal upstairs as a temporary measure but would live to have my Nighthawk working again.
